Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 427 build
Thread: 427 build
Old 09-18-2012, 05:31 PM
377tk's Avatar
377tk 377tk is offline
427 build
I am building a 427 +30 based on a mid 70's 454 block I currently have 11 to 1 forged TRW domes forged rods and forged oem crank. Assembly has been balanced at machine shop. Have the heads and intake are at the machine shop having port work done and the intake port matched. The heads are 781's and intake is an RPM. Issue is looking at cams. Money isnt allowing me to run a roller but am looking at the 294s and 11-606-5 comp cams. Prefer staying with solid flat tappet and other suggestions would be appreciated. It will be going in a 80 malibu, currently has a 3500 stall and gears will be changed out to 3.73's and am running mt 29x10.5 rears. Car is licensed but not worried about streetability and I know compression is a limiting factor. Wanting to be running 11.5 or better in the 1/4mi. with out power adders
