Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 427 build
Thread: 427 build
Old 09-20-2012, 06:01 PM
377tk's Avatar
377tk 377tk is offline
The engine builder I got the rotating assembly from said it will work good with the 781 heads. I am not to worried about the compression or idle. I believe the overlap will take some of the compression out, probably not much and from there I'll see what I need. My current engine is an old circle track engine flat top 350 solid 292 cam with 540 lift 210 runner heads a 2925 super vic intake and a 750 hp with a 3500 stall. Idle is 1400 in park and 1200 in gear with a hell of a lope. I enjoy borderline streetability, dont drive on the street much but it gets looks and runs well. I thought about having the 294s ground on a 108 instead of a 110 any suggestions? I have a cam grinder that will grind any cam I want for $40 plus shipping as long as he has a compatable core then he has it hardened before sending it out hes just hard to reach. thanks for your input
