427 HP q'S - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2009, 11:42 PM
427 HP q'S
1966 427 bored .06 over eagle forged racing rotating assembly 4.375 stroke and 6.385 rods with JE SRP 18cc Dome Piston (~10.5:1 w/ 118cc) heads. Perfect Circle or Mahle Plasma Premium Performance Rings. Clevite or King Competition Series Rod and Main Bearings. with patriot performance aluminum heads. 119cc combustion chamber. rectangle intake ports and round exhaust ports. 320cc intake runners. 2.25 intake valves and 1.88 exhaust valves. wiend tunnel ram intake with duall holley 450 or 600 cfm carbs. im not sure what would be a good cam but heads allow up to .7 lift. how much hp approx? and any cam suggestions?
Old 10-21-2009, 09:53 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Hmmm, 3200 bucks just for the heads....this could be a very expensive build.
https://www.patriot-performance.com/...&cat=33&page=1
Old 10-21-2009, 11:03 AM
Will everything clear with a 4.375 stroke? Is there an off the shelf piston for that combo? Might find that 4.375" stroke pistons start out at about 4.5" bore.
Old 10-21-2009, 06:56 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
actually those heads are 1600 for a pair . Thats very reasonable for a bbc.
Old 10-21-2009, 07:41 PM
1969NovaSS's Avatar
double post
Old 10-21-2009, 11:33 PM
mudbogger yes those pistons come in a kit im purchasing from adperformance that is an all forged eagle racing kit that i can order .06 over.
yes tech inspector, nova's right there a pair for that price. but the engine is goin to cost me about 5500 after its done eventually i plan on supercharging it but that a couple years after i finish pilot school
so can any1 give me a ball park hp rating on that engine???
Old 10-22-2009, 04:46 AM
Hmmm might have to pick one up myself!
Old 10-22-2009, 09:23 PM
ya its a good deal at 1800.00 but can anyone please answer my post questions on approx. horsepower?
Old 10-23-2009, 05:17 AM
Last journal entry: PICTURE TEST
build
Do not buy those heads. they are the China casting heads that they re-work..
Spend a few hundred more and get a set of Edelbrocks,,,, you will thank me for it later.
Hp guess is just that, a guess. You can run the numbers on desk top dyno and get 575 hp...then strap that engine on a real calibrated dyno and pull 425 hp...
There are just way to many things that dictate what hp the engine is going to actually make.
I ahve a program that if you tell it the truth will get you with-in 3% of a calibrated dyno for HP,but i need way more info then you gave to even start entering numbers.
At 17 years old my question would be, how much HP do you need, and what do you need it for???
Keith
Old 10-23-2009, 05:42 PM
well i think itl be more than that just cause it started off life as a 390hp engine and im boring it .06 over and stroking .35 in over stock and getting alumin big valve and runner heads i think im just hoping that droping that much money in it will get me mid 600's hp wise and its goin in a street/strip 1956 f100. even though im only 17 please dont underestimate me guys.
Old 10-23-2009, 05:50 PM
airboat's Avatar
Sorry, Lousy mood!
Old 10-23-2009, 11:36 PM
look man im not wanting to start crap with you ok im just tryin to learn as i go ok geez liten up
Old 10-24-2009, 07:44 AM
Depending on head flow cam etc. you could end up between 375 and 800 hp it just all depends on choices made.The important ? first is what do you intend to use the truck for? strip only? street/strip, cruiser daily driver? this question must be answered then we can proceed from there.
Old 10-24-2009, 11:32 AM
thanx barnym17 its goin in a street strip truck but its mainly gunna be on the street and its a 1956 f100 short bed stepside
I need intellegent input concerning HP ratings. glen242 Engine 24 05-22-2008 05:56 PM
eagle crank hp rating. engineman302 Engine 4 04-10-2005 04:38 PM
260 HP or 290 HP GM Crate motor Iceberg Engine 4 02-26-2005 01:26 PM
A few changes to 540 hp carcraft buildup... what kind of hp loss? guesstimates please elukas Engine 16 08-07-2003 07:54 PM
didn't know where to ask this but HP and TQ relationship? stonedchihuahua Hotrodders' Lounge 11 12-14-2002 03:02 PM
