I think you can bore it to..125 over safely.without using hardblock up to to the coolant holes in the block. So bore wold be 4.375 has for.as.stroke.you can fit a 4.500 with clearancen.maybe more. Could possibly for 4,750 stroke. Go 4.440.bore with hard block fill.
that's close to a.4.500 bore of.you think of of that only. .060 more or think of of like this only. .030 per side
personally. I got a. Dart bigM block
use the above.formula to find out cubes good luck
