427 tall deck motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2012, 07:12 PM
427 tall deck motor
im tryn 2 c how much wud i have 2 bore a tall deck block, what size rod, & what size crank i wud have 2 use 2 make it a 540?
Old 03-08-2012, 08:56 PM
Bore x Bore x Stroke x Number of cylinders x .7854
(Example) 4.5 Bore x 4.5 Bore =20.25 - 20.25 x 4.5 Stroke=91.125 - 91.125 x 8 cylinders=729 - 729 x .7854= 572 cubic inches
Old 03-08-2012, 09:47 PM
I think you can bore it to..125 over safely.without using hardblock up to to the coolant holes in the block. So bore wold be 4.375 has for.as.stroke.you can fit a 4.500 with clearancen.maybe more. Could possibly for 4,750 stroke. Go 4.440.bore with hard block fill.
that's close to a.4.500 bore of.you think of of that only. .060 more or think of of like this only. .030 per side
personally. I got a. Dart bigM block
use the above.formula to find out cubes good luck
Old 03-08-2012, 09:50 PM
Or bore x bore x.stroke x.7854 x 8= cubes
Old 03-08-2012, 10:03 PM
ok Stinger460.thnx 4 da info.so will da machine shop have 2 notch da block or will da 4.5 stroke drop rite in?
Old 03-09-2012, 06:14 AM
BOBCRMAN@aol.com's Avatar
EVERY block is different. When I sleeve these, the OD of repair sleeve is 4.440+ and there is still over .100" still in the original wall. So a .125 overbore should not be a problem. I have drag raced them with no problems. A 4.50 stroke crank will probably need some clearance work. Depends on other factors. Such as Type and length of rods. Crank counterweight style.
Old 03-09-2012, 02:12 PM
Cheapo BBC 505 tall deck grunt motor techinspector1 Engine 18 06-05-2014 12:59 PM
427 tall deck or 454 motor bluegmc1956 Hotrodding Basics 3 01-22-2011 05:55 PM
427 tall deck truck motor prostreethotrods Electrical 6 11-18-2009 11:13 PM
Tall deck 427, first motor build? freeninetynine Engine 22 08-09-2009 01:13 PM
tall deck motor question Ratoflic Engine 6 12-05-2005 02:25 PM
