427 tall deck motors - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2006, 03:39 PM
to install in 70 chevelle. will use existing crank but need new rods & pistons.
what would you advise.? ?
Old 10-24-2006, 04:12 PM
I would go ahead and get a crank as well while your at it anyway and make it a stroker
Old 10-24-2006, 10:21 PM
BOBCRMAN@aol.com's Avatar
Cheapest bet is to go with aftermkt rods. 6.535" long and use readily available 427 pistons. Don't forget manifold spacers or correct intake for that .400 taller block.
Next best bet is a 454 crank .400 long rods and 454 pistons.
After that you get expensive! Either custom length rods and/or pistons are required.
Old 10-25-2006, 08:24 AM
Last journal entry: PICTURE TEST
engine
A tall deck in a chevelle might have issues with the headers hitting the upper control arm bolts....Just a heads up for you.
Keith
Old 10-25-2006, 10:43 AM
I think you are making a lot of extra work for your self. There is no advantage in using a tall deck block with a stock stroke. Several reasons not to use it. More weight, intake, distributer, exaust clearance. Better off using a short deck block.
Bob
427 TALL DECK block icebreakr1969 Engine 20 10-07-2011 01:01 AM
What is the differrence between a 427 chevy bb and a 427 chevy tall deck brian12c Engine 11 01-29-2007 10:58 AM
678Hp @ 7200RPM 427 tall deck 6426yy Engine 2 08-15-2006 04:30 PM
500 crank in a 427 tall deck? brian12c Engine 3 04-25-2005 07:52 PM
tall deck 427/ bunk or go for it el Engine 3 01-09-2003 08:33 AM
