427 tall deck truck motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2009, 08:02 PM
prostreethotrods's Avatar
does any one know of what type of distributor i can use for this tall deck block...can i use a regular distributor with a longer gear drive or does it have to be a tall deck one
also can i use a regular intake manifold or does it need spacers with this block
Old 11-18-2009, 09:00 PM
life is a temporary assignment
You have to have one with a slip collar..I cut my dist and made a slip collar for mine.
They make a nice intake for the tall deck motors..
Old 11-18-2009, 09:01 PM
BOBCRMAN@aol.com's Avatar
If you use a "regular" manifold. Yes , you will need intake spacers. If you use spacers, you will need to have the manifold modified for a standard height distrib. Or use a distrib with a "slip ring" adjustable height. Available from MSD and other aftermkt. suppliers.
Old 11-18-2009, 09:18 PM
what does this slip ring distributor look like
Old 11-18-2009, 09:25 PM
looks like normal Chevy distrib. The collar that holds the distrib to the intake is actually a slip ring with an allen screw in it. Allows adjustment up and down.
Old 11-18-2009, 10:24 PM
thx for the info
Old 11-18-2009, 11:13 PM
Here's one here.. They are very easy to make, If you have a Lathe..
427 tall deck. DoubleVision Engine 5 10-05-2009 03:50 AM
427 Tall Deck to 572 cu in Aruba1 Engine 17 09-09-2009 11:00 PM
427 Tall Deck Rebuild emcdermott Engine 2 02-15-2003 06:42 PM
tall deck 427/ bunk or go for it el Engine 3 01-09-2003 07:33 AM
427 Tall Deck Rebuild MudFrog427 Engine 2 10-03-2002 06:57 AM
