Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 427T Gen V Flywheel
Old 12-31-2005, 03:42 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
I`ll take a stab and say with any 1 piece rear main setup it should require a weighted flywheel and there for needs an external balance...? The 2 piece rear main type cranks have some weighting on the flywheel flange so SOME do not need an external weight (454`s and larger do)...
But as a 1 piece rear main 350 (87 and later) requires a weighted flywheel (not the same as the 400 weighted flywheel) then a BBC of the same config should also need this for proper balance...
