427T Gen V Flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2005, 10:27 AM
JDL JDL is offline
427T Gen V Flywheel
I had an 86 366T two piece rear seal that I just replaced with a 91 427T one piece rear seal.. I reused the 427T balancer.. but used the 366T flywheel. As you might guess I have a vibration problem.. Does't get progressively worse but just at certain rpm ranges.. I was told the two piece 366T and 427T flywheels were the same.. but no one could tell me anything about the Gen V 427T one piece flywheel.. Anyone know the answer...?
Old 12-31-2005, 03:42 PM
Bumpstick's Avatar
Hammer and a torch
I`ll take a stab and say with any 1 piece rear main setup it should require a weighted flywheel and there for needs an external balance...? The 2 piece rear main type cranks have some weighting on the flywheel flange so SOME do not need an external weight (454`s and larger do)...
But as a 1 piece rear main 350 (87 and later) requires a weighted flywheel (not the same as the 400 weighted flywheel) then a BBC of the same config should also need this for proper balance...
Additional 50hp from heads, or 200+lbs off the nose from a LW front suspension clip? NLang General Rodding Tech 29 12-15-2005 02:31 PM
GM Gen III/IV V8s Blazin72 Engine 14 10-05-2005 08:44 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 06:44 PM
Flywheel balancing? nomis30 Engine 3 11-25-2003 11:03 PM
