428 timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2002, 01:55 PM
Mertz's Avatar
Post 428 timing
What would the correct timing be for a 69 Pontiac 428? I have it set at 8 BTDC. I think its a stock cam. The engine runs hot at slow speeds and there is a occassional backfire through the carb. I has pretty good power but I think it should move my Catalina convert. a little better even if it is the 360 hp version. I'm running a Carter AFB 600 or 650 cfm and Caddy automatic.
Old 08-08-2002, 02:15 PM
bullheimer's Avatar
NEVER use credit cards!
Post
there's a guy -Drew- selling a 428, ask him. what do you mean you think it should be faster? i was thinking about getting it.
Old 08-08-2002, 02:29 PM
Mertz's Avatar
Post
If I had the money I would get it too. But I have nothing to put it in except maybe my 40 Plymouth truck or my 85 chevy pickup.
The Catalina convert is very heavy. I am not sure that I have it running at its top performance. I have not been able to locate the kickdown switch for the tranny so I can't enjoy that peddle to the floor acceloration.
I have some backfire so I am not sure if everything inside is in good working order. I tried to clean out the carbon with some heavy duty carbon cleaner and it made the backfire worse for a while. It seems to be running much better now.
I believe they only made the 428 for 3 years 1967 to 1969. So far I have not had any trouble getting parts. It have an Edlebrock alum intake.
I think the price for the motor is pretty good. If it wasn't for the shipping I would be looking at it too. To bad he is not in WA
Old 08-09-2002, 06:44 AM
Post
Timing should be 8-10 initial and no more than 34 total all in by 2000rpms. With the backfire problem it sounds like maybe a rich or lean condition in the carb. Look down the inside of the carb when it's running and make sure there's not a drip.
