429 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2012, 07:58 PM
429 ?
Hi there new here ...I have a 1970 galaxie xl with a 429... the vin said it should have a 289 hipo..0g60k//////...so i was looking at the block and the code from what i can see is D1VE 6015-A2B....heads D0VE-C ..tag on the intake 429 70 6 2nd line ?c k815 ag just hoping that some one out there can tell me what I have....the motor sounds good com...150 psi..has a holly p- 80 carb...thats all I have..now..Thanks
Old 12-23-2012, 08:04 PM
vinniekq2's Avatar
welcome to the forum. Sounds like a nice car,glad its not another chevy
Old 12-23-2012, 10:53 PM
carolinacustoms's Avatar
Automotive Extraordinaire
I believe that would make it a 71 460, or possibly a 429 that someone put 460 heads on. Maybe someone else can confirm that or correct me if I am wrong. And Are you sure it is supposed to have a 289? 1970 would have been a 302, 1968 was the last year of the 289
Old 12-23-2012, 11:32 PM
RWENUTS's Avatar
http://www.crankshaftcoalition.com/w...tify_a_Ford_V8
Old 12-23-2012, 11:37 PM
Correction
I have been corrected...found a sheet on 1970 ..and the ..k..in the vin..is a 429...2b...
Old 12-24-2012, 07:39 AM
That is probably a 1971 429 4V Thunderjet. If it has the factory flat top pistons that will be a high compression engine in excess of 10:1. With a stock cam you will definitely need to run 93 octane and be careful with the ignition timing to avoid pinging.
Old 12-24-2012, 06:13 PM
LATECH's Avatar
X2.....
Fact is stranger than Fiction
429 Wants To Diesel On Me?? IRELAND EXHAUST Engine 8 01-10-2008 03:03 AM
429 help BrettB Introduce Yourself 2 05-11-2006 05:50 PM
429 mpodjan Introduce Yourself 2 09-15-2005 10:51 AM
ford 429 nos_429 Engine 14 11-23-2003 01:48 AM
429 cj twjones Engine 1 10-11-2002 04:11 PM
