429 to 460 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2010, 10:02 PM
jameshi's Avatar
71 ford high boy
429 to 460
i am looking in to building a 460 from core up
what do i need to do to a 429 to make it a 460 if it is all possible
will this one work
(C8VE is the casting number. These are cobra jet heads. They have been sitting outside for a year and need to be rebuilt)
or this on
(I have a 429 ford Big Block the block and every thing that is in it is in good shape, The motor ran good when I removed it from the car. I do have a set of heads for it if needed. The the motor has DIVE stamped on it)
Old 06-20-2010, 10:45 PM
429/460 blocks are the same and have the same size bore. to make a 460 all you need is a 460 crank. the C8 heads you have are not cj heads. cj heads are D0OE-R.
what was the D1 block removed from? if a t-bird it mite be a 460
Old 06-20-2010, 10:53 PM
jameshi's Avatar
71 ford high boy
they are both off craglist i just want to no what one is the best to use in a 71 ford f250 i have one is for fun and the other is for show and power the one i going to put this in is the show one
Old 06-20-2010, 11:09 PM
ericnova72's Avatar
More for Less Racer
I have seen the C8's listed as "Thunder Jet" heads, they are not Cobra Jet/Super CJ. They are closed chamber and have 75-76cc chamber, good for making compression, screw-in "bottleneck" studs with no guideplates and self guided rockers, 2.08"/1.65" valves. A decent head to use, put bigger valves in and port, they are far better than any D2 or later smog head.
All you need to turn a 429 into a 460 is the crank and the pistons. Rods and block are the same between the two.
Old 06-20-2010, 11:26 PM
jameshi's Avatar
71 ford high boy
are the heads the same or do i need to get bigger heads
Old 06-21-2010, 12:31 AM
What are your goals? Those C8 heads on a 460 should have no proplem supporting 400 horsepower
Old 06-21-2010, 12:37 AM
Check out 460ford.com. Lots of good info and builds on there you can do to match to meet your goals
429 Cobra Jet Question Chevytruck Engine 6 09-28-2008 02:39 PM
460 vs 429 crank? classicgarage Engine 3 06-19-2008 05:33 PM
Issue with Ford 460 clutch onebadmerc Transmission - Rearend 1 02-22-2007 06:15 PM
460 flywheel, 400 pressure plate? billybob_v10 Transmission - Rearend 2 07-02-2004 11:51 AM
400 to 429 in 79 lincoln DusterNut Engine 4 11-25-2003 09:57 PM
