Internal balance engines, you can use a 390 flywheel/ clutch and 351M/400 bellhousing. External balance engines you need a 460 flywheel because there is no weighted 390 flywheel, and that makes clearence issues with the 351M/400 bell, because there shorter. You can get some shim plates and make it work.
