-   -   429-460 bellhouseing (http://www.hotrodders.com/forum/429-460-bellhouseing-220326.html)
roush_racer22 06-08-2012 03:38 AM
i took a 429 thunder jet out of a 71 Thunderbird i want to put my std tranny on the motor but im unsure what bell housing and flywheel will work i have a new flywheel of a 77 460 will this work on the 429 and is it balanced different ? im doing this swap in a 68 f-100 the 429 has a c6 behind it but i have a wide ratio 4 speed i would like to use
timothale 06-10-2012 08:10 AM
pilot bearings size
Ford changed pilot bearing sizes some where along the line, some big blocks used the same size as FE ( 390) engines.
matt167 06-10-2012 08:25 PM
429-460 before 1978 is internally balanced. You can run a 390 flywheel and clutch with a 351M/400 bellhousing.
roush_racer22 06-12-2012 03:34 PM
bellhousing
so on my 71 429 im gonna want to run a 390 flywheel and i have a 400m bellhouseing but will one off a 390 one work better i no a 400m will not work on a 460 it makes it stick iv tryed that before
roush_racer22 07-22-2012 05:57 PM
so im gonna want to use a flywheel and clutch of a 390 and a bell housing of a 400m i put a 400m bell houseing on a 460 once dident work out so hot but i have a bell houseing for a 400m 390 and a 460 and a flywheel and clutch off a 390 or of a 83 460 ???
matt167 07-22-2012 06:06 PM
Internal balance engines, you can use a 390 flywheel/ clutch and 351M/400 bellhousing. External balance engines you need a 460 flywheel because there is no weighted 390 flywheel, and that makes clearence issues with the 351M/400 bell, because there shorter. You can get some shim plates and make it work.
roush_racer22 07-22-2012 08:40 PM
ok i got yea so the 351m/400 bell housing will be fine on my 71 429 because its Internal balance and like i said i tried that on a 460 but the 460 was an 80 so it was External balance makes sense now i really appreciate it
