429 and C6 into a 55 Ford Fairlane - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2007, 11:59 AM
Last journal entry: Brake? Steering?
Does anyone know if there is a mount / adapter available to bolt the 429 Ford engine directly into the stock motor mount flange on the 55 Ford Crossmember? How about the C6 rear mount? I would imagine that the trans mount would be a bit less confusing. The 55 Ford Crossmember with mounting flanges for the engine is also the lower control arm mount so I don't think it's possible to weld in the Trans-Dapt style of mount that welds to the frame of vehicles that are from 28" to 38" across. HELP!
Thanks!
mounting a 429 into a 55 Ford Rons1stRod Hotrodding Basics 29 04-03-2007 01:36 PM
41 Packard 110 w/ 429 SCJ, C6 & 9" Rear 41pac Introduce Yourself 1 10-18-2004 05:02 PM
400 to 429 in 79 lincoln DusterNut Engine 4 11-25-2003 09:57 PM
Crank Pilot size for 429 Ford '67Pony Transmission - Rearend 0 10-01-2003 03:00 PM
