Does anyone know if there is a mount / adapter available to bolt the 429 Ford engine directly into the stock motor mount flange on the 55 Ford Crossmember? How about the C6 rear mount? I would imagine that the trans mount would be a bit less confusing. The 55 Ford Crossmember with mounting flanges for the engine is also the lower control arm mount so I don't think it's possible to weld in the Trans-Dapt style of mount that welds to the frame of vehicles that are from 28" to 38" across. HELP!
Thanks!
Thanks!
