429 Cobra Jet Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2008, 02:53 PM
Hells Workshop
Hey everyone, i found a guy with a "460" ford block for sale, it comes with the crank turned 0.10" as well. He is saying that the numbers on the block are
D1VE 6015 AA. From what i can find on the net, i'm figuring it is a 71 429 Cobra Jet and not a 460. It is just a bare block with crank, no heads or anything else to look off for info. Have i hit the jackpot here or is it just an everyday 460, Thanks.
Old 09-23-2008, 03:19 PM
Shelby1's Avatar
Steel Dreams
get the numbers off the crank ,that will tell you which one it is . The blocks are the same.
Kenny
___________________________________________
You can't license or legislate intelligence
Old 09-23-2008, 08:45 PM
scottford351's Avatar
The Cobra Jet block was a 4 bolt main
Old 09-23-2008, 10:53 PM
Yeah, four bolt main is the big give away.
Old 09-24-2008, 03:47 PM
woodz428's Avatar
Troll Hunter
The V in D1VE is for Lincoln or 460. The number is listed as having some used in CJ's but I would be sceptical. As pointed out it would have 4 bolt block, in most cases, if it was a CJ. It is also the number used in bread and butter 429 engines. A visual is the best.
Old 09-24-2008, 04:08 PM
onebadmerc's Avatar
I need a bucket of arc sparks
The block numbers you have posted is just a garden variety 429-460 block. I have two D1VE blocks in my shed and one in my truck, one is a 429 and two are 460's.
Old 09-28-2008, 02:39 PM
AA suffix is important.
cobra jet deven Engine 5 11-09-2006 08:07 AM
ram jet motor question.... blacksc Engine 6 10-19-2005 12:53 PM
q jet mixture question mikeweyman Engine 6 08-24-2005 07:48 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
Q Jet on a 327, question by newcomer 66nova guy Engine 7 09-15-2003 09:58 AM
