429 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2006, 06:57 PM
429 engine
can you tell me about this engine #s are C9VE-B (b1386)or 9Z535816
Old 04-25-2006, 09:04 PM
The motor came out of a '69 Lincoln. 2 bolt mains, medium-to-low compression, standard heads. No big deal.
Old 04-26-2006, 05:44 AM
aka Duke of URL
How do you know it is a 429? FORD/MERC used the 429 and LINC used the 460. Off of what component did you pull C9VE?
Old 04-26-2006, 06:39 AM
Kultulz is correct; it is probably a 460.
Old 04-26-2006, 03:08 PM
429 engine
the # came off the block and the heads, do you no what hp it has
Old 04-26-2006, 06:05 PM
aka Duke of URL
9Z535816 is the partial VIN from the vehicle. 9 is the model year (1969), Z is the assembly plant (St. Louis) and 535816 is the sequence number of assembly. LINC-MERC sequence starts at 500001 so it should be a 460. I believe they were rated @360HP that model year.
The block casting I.D. No. C9VE is a 429/460 block. For further I.D., you would need to look for the engine tag, carb I.D.tag, etc.
Old 04-26-2006, 07:10 PM
429 engine mud bod truck
if someone can tell me what the biggest cam i can throw at this 429 or 460 that would be great. and also this motor is going in a 1975 f250 truck with 38 and 44 in, tires, this truck is going to be at high rpms in the mud for a min or two. what would be ideal for this motor and what size stall convertor, the motor is rated about 360hp stock. do i give it more gas and air flow. change intake,what size carb. thanks for responce
Old 04-26-2006, 09:12 PM
Last journal entry: Project "Black Sunshine" Started
429 engine
The only diffrence between a 429 and a 460 is the crank. And both can take a lot of power. Their one of the few that can be borred way way over and still be good to drive and or race. And they run best with 750 carbs on them me and my dad has found that Holley is about the best to use on a Ford product.
ENGINE BALANCING NAIRB Engine 22 01-23-2016 02:44 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 01:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
question for any engine builders out there mopar72 Engine 7 11-06-2005 04:06 PM
