434 SBC with small journal rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2007, 07:19 PM
I have a Callies 4" stroke crank that needs to be reground, as it spun a rod bearing. The crank grinder said he could take it to small journal size and we could run SJ rods on it. Does it make it a bad choice to do this? This is going in a pulling truck (Hot Stock class). Will this be weaker due to the long stroke w/ small journals?
Thanks, Brad
Old 09-20-2007, 08:54 PM
DoubleVision's Avatar
While I know callies makes a excellant crank, if it were me, I wouldn`t do it, to go from a large journal to a small is taking a heck of a chunk off the journals. While I know wide fillets make a crank stronger I`d still think there`s a limit on how far down you can go. With the load your putting on the crank at that stroke and power level, I`m not sure I`d feel real safe.
Old 09-20-2007, 09:35 PM
How f-ed is the crank, it may be able to be ground and rechromed back up to 030 or somthing, real good crank shops can do this well. durability wise winston cup ( never nextel) guys use honda 1.88 journals on billet cranks. small chevy journals are 2.00 so it has been done, not 434 cubic inches mind you.
Old 09-20-2007, 10:28 PM
Thats a lot of over lap going to a small journal and some times machining a journal down that for will move the oil hles closer to the radius of the crank journal.
The cup guys can get away with that cause there using short stroke cranks around 2.250 and up.
At the begining of the season Toyota was using a 1.750 mains on there cranks.
Old 09-14-2008, 09:04 PM
Thanks, Brad
4 inch stroke cranks with 2 inch journal. i do it with scat 4340 cap screw rods. tight clearances and M140 3/4 groove mains. i build alot of 1.889 rod journal engines. nothing breaks. use a 6 inch rod. you have to clearance the rods to the cam lobes andthe bottom of the cylinder bores on both sides of the block. JE piston with a deck height of 1.062. these engines all run plus or minus 7 grand on dirt circles....just like pulling in the dirt.
Old 09-14-2008, 09:10 PM
A deck height of 1.062 man thats the smallest deck height I have ever heard of LOL.
Or do you mean compression height ?????????????????
Old 09-14-2008, 09:26 PM
Be careful who you have work on your crank.
I'd Call These Guys...
Marine Crankshaft Inc.
2155 S. Grand Avenue
Santa Ana, CA 92705
714.549.2388 Fax 714.549.1382
Email: CACranks@yahoo.com
I am not a compensated agent, endorser, or seller of any known or unknown product or service.
Old 09-14-2008, 11:01 PM
buy some books...then we can talk...sensably
Old 09-15-2008, 01:43 AM
327NUT's Avatar
Hey Adam's.......for a new guy with only 2 posts thats a pretty salty reply "buy some books...then we can talk...sensably" to CNC's question, which was quite valid and sent in a good natured way. And by the way, you spelled "sensably" wrong.....sensibly (Webster's).
Old 09-15-2008, 03:17 AM
techinspector1's Avatar
Wiki Edits: 326
hahahaha, the guy uses the wrong nomenclature and then wire-brushes CNC for using the correct one.... hahahaha
This is for the newbs, so they don't get confused by the last few posts, so don't anybody else get their shorts wadded up.
Block Deck Height: the distance from the centerline of the main bearing bore in the block where the crankshaft main bearings reside, to the flat surface of the block deck where the heads bolt on. (usually 9.000" to 9.025" on a SBC)
Piston Deck Height: the distance from the piston crown surface to the block deck with the piston at top dead center. (usually 0.040" to 0.000")
Piston compression height: the distance from the centerline of the wrist pin bore in the piston to the piston crown. (usually 1.000" to 2.000")
Old 09-15-2008, 04:22 PM
I was thinking the same thing, when I read it. But I figured since I posted this about a year ago and that particular crank is long gone, I'd leave it alone....
Old 09-15-2008, 11:12 PM
Shouldn't be a problem assuming you're not using a novice machinist.
I know most machinists are way past the expert level of knowledge.
There is the remote possibility that you might find the wrong guy to do the job.
The best way to find a good shop is if it's VERY BACKED UP & you see nothing but Chevy Small Block parts on the floor.
I heard of a guy that was cheap & fast that did crank grinding with ZERO fillet radius.
If you choose to go to the cheapest & fastest guy it's like playing russian roulette. You never know what you're gonna get.
SBC stroker project, small budget jankinnu Engine 63 11-21-2010 11:53 PM
Scat / Pro Line connecting rods, sbc. Rad Ray Engine 3 12-12-2007 09:38 PM
Problems with rods on chev. small block Larry Wilcox Engine 3 01-09-2003 06:13 PM
Small Journal bowtie741 Engine 2 01-08-2003 04:02 PM
SBC Rods 68NovaSS Engine 5 09-25-2002 07:44 PM
