43430 or 90977 spray gun?
I've been reading around and it seems a lot of folks on this site really like the Harbor Freight 43430 and/or 90977 spray guns. Do people use them both for primer and base/clear, etc.? 2 different tips, 2 of the same guns, 1 of each or what?
I've search around a bit and it seems like the most commonly recommended gun was the 43430. Since this is the cheaper of the two, I wanted to make sure I got this right, that it's recommended over the more expensive 90977? I realize it's subjective, but any feedback is appreciated. I'm only going to use the gun(s) to paint a few panels on my Fairlane. My compressor has this spec: Flow Rate : 11.5 SCFM @ 40 PSI, 10.2 SCFM @ 90 Thanks |
Actually could someone just tell me if the 43430 would be okay with that compressor? I see the "air hog" comment all over. Would I be better with a lower cfm gun or would it even matter since I'm over the 9.5 minimum?
Hf 90977
I use a Harbor Freight gun model 90977.
This was my first paint job. I sprayed primer, base coat and clear with this gun. I thought it performed great! Attached is a picture of the van. I painted the hood and grill area. I have also painted a bow (archery) with it, metal flake, turned out great. I only have a 3 hp 21 gal. compressor from Harbor freight. At first my compressor wouldn't keep up, so I put hi flow connectors on all connections. And it works perfect. I spray @ 29 psi with this gun. Last edited by brianc; 07-31-2009 at 03:00 PM. Reason: add pics |
Harbor Freight 90977 Spray Gun
Just did another hood last weekend. I used the Harbor Freight 90977 gun. This was a tricoat job. Primer, base, midcoat, and clear. I thought it really came out nice. Matched really well. I did a test panel first of 1 to 6 coats of the midcoat so I could determine how many coats of mid to put on.
I used Limco 800k primer, Diamont paint, and Norm's Clear Coat. Last edited by brianc; 08-14-2009 at 08:16 AM. |
I prefer an Accuspray 10, or 11 series, and I swap the fluid tip, and air nozzel depending on the material.
I've found that while they are ugly, they are light weight, and use less air pressure, thus, putting more material on the surface. I've tried the Harbor freight, and the husky, and a couple of others, and found that they want to start shooting onesided, after a few days of use. I've been using the same two Accuspray guns (one for color, and one for clear) for about 8 years now, and have had no problems with them yet. |
the great thing about acuspray gun is that they can be taken apart and completly rebuilt
My dad uses these sata,and iwatha at school where he teaches high schooler that don't give crap about taking care of tools and these have held up well. Also the gun bodies are made from kevlar so they hold up well |
Now that's my kind of hotrod! A lot of people may think it somewhat of a waste to use $400 a gallon paint on a tractor but hey, old tractors need lovin' too!!
| Recent Garage - Tools posts with photos |
| Martin Senour Tech Sheets? | unstable | Body - Exterior | 42 | 03-12-2011 09:09 PM |
| low priced spray gun/detail gun for primer/base/clear and ghost flames | jrmy_1 | Body - Exterior | 15 | 06-08-2008 06:38 AM |
| shooting clear | vinvango73 | Body - Exterior | 3 | 10-28-2005 11:24 PM |
| Orange peel in the clear | Montypierce | Body - Exterior | 13 | 03-06-2005 08:49 PM |
| harbor freight hvlp gun | jn0w | Introduce Yourself | 2 | 06-15-2004 03:08 PM |
