43430 HF gun? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-08-2009, 01:55 PM
Last journal entry: New photos
Do you know how to set up your gun? Do you have a regulator at your gun inlet. A mistake I did early on was setting the pressure without pulling the trigger. I got a lot of peel. I find setting your pressure first, then your fan (6-8"), and then your fluid volume to control runs works best. I just painted a car and used 12" wide aluminum flashing to tell me what my gun was doing and it worked great.
  #17 (permalink)
Old 11-08-2009, 02:08 PM
Originally Posted by brandonA.
I am still confused as to which gun would make the compressor work harder. I believe it is the HVLP due to what it is rated at..... I am correct or missing something. I know my compressor can handle my conventional gun but HVLP is another issue... It is rated for more cfm= 9.5 to 14.8 cfm and my conventional gun requires 4-7cfm.
-If not what conventional gun gravity feed would be good to use for under $100.... Is this HF 47016 gun a good spraying option?
Thanks for the reply!
HVLP, high VOLUME and low pressure, what this means is the gun uses a higher volume of air (more CFM) and it simply does not matter what the pressure is. A conventional gun like that 47016 would use a heck of a lot less air than the 43430 but I have no idea how well the 47016 would work, just can't see trying to paint a car with a $10 gun and expect much. I can however attest to the fact that the 43430 most certainly will spray AE and spray it well! I use a 43430 to spray AE with and it does a really good job, for these cheap paints I will use it instead of my Iwata but for sure your compressor is no where near up to the 43430's requirements.
  #18 (permalink)
Old 11-08-2009, 03:46 PM
Thanks that's what I was looking for!!!
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Thinkin about the HF Purple Spray Gun 43430 it's on sale TT66' Garage - Tools 8 02-22-2007 12:51 PM
2.2 tip for 43430 HF Gun... S10xGN Body - Exterior 9 01-22-2007 07:37 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
