Post the VIN Number and I'll decode it for you.
If memory serves me right, it can be found on the passenger side of the engine, just above the oil pan.
Since I posted I have found some info. The 440-3 is an industrial engine also used in some motor homes. It is a heavy duty, with different water passages in the block and heads, there fore uses a different gasket set. Have not been able to find any info on engine internal parts. Even called 2 Dodge dealerships and numberous parts houses, no info as to wheather it uses stock 440 parts or not.
Jack
Forgot to add, Dodge stopped production of the 440 in 1978. The 440-3 was produced until the mid 80s.
Jack
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
