440 chrysler Model A - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2005, 11:45 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
What does everybody think? I have a 1931 Model A, that I have planned for a LT1 SBC. But I just thought of putting a 440 Chrysler engine in it. I will box the frame for either engine, is there anything else I would need to do to the chassis to hold up to the 440? Do you see many 440's in Model A's? I have never seen one here in Michigan. I also have 383's but I think the 440 would be the best of the 2.
Steve
Old 06-13-2005, 06:48 PM
A SBC is a hood full for a Model A........
A 440 is longer, wider and heavier........major firewall issues .......and the width with exhaust may be too wide for a Model A hood to close.......without the 440 being 6 or 8 inches into the car.
Cooling......a whole lot of Model A guys have trouble keeping a 350 Cubic inch Chevrolet cool ........in a Model A. .......And you are going to add almost 100 cubic inches...?
But it would be DIFFERENT.......!!
Old 06-13-2005, 06:57 PM
Wiki Edits: 49
I agree with Deuce. It can be done but you're looking at some major mods to the firewall at the least. Exhaust won't be a problem if your going fender-less but as Deuce said it sure would be different.
One alternative you might consider if you want to go Mopar would be one of the Mopar small blocks 340/360 or even a hopped up 318 might be a better choice. Just a suggestion.
Old 06-13-2005, 07:38 PM
spinn's Avatar
its a shame, the 440 is about the finest engine. garranteed to give the full blast off!
Old 06-14-2005, 09:38 AM
Frisco's Avatar
Glad To Be Here
Steve
Go for it! Box the frame all the way back. Set the engine back far enough to run the stock water pump / fan combo. Use a good aftermarket radiator (I prefer Walker). The firewall will of course have to be set back and this will take away from interior leg room. If you desire to run a hood; use just the top sections. Leave the side panels off to "Show what You've got" and I think lake pipe style headers would really set the look off well. ENJOY!!!
I like this choice for the difference and the awesome results.
440 question?????? HemmiGremmie Engine 8 08-10-2008 04:55 PM
Model T Frame adtkart Suspension - Brakes - Steering 19 01-07-2008 09:53 PM
What car (make and model) can be use to place a Model A body? Fortingo General Rodding Tech 7 05-10-2003 03:25 PM
confusing question about cars and their weight stonedchihuahua General Rodding Tech 14 03-27-2003 03:00 PM
What is wrong with a chrysler 68newport383 Body - Exterior 23 02-11-2003 04:35 AM
