Update: I got it weighed at the recycle center and it was 4000 lbs exactly (1994) was last time I weighed it. Good news I guess. I figure 500hp would please me. Could a shop build a 440 to my specs for around $3000
you've got "champagne taste's" on a beer budget!!!!
(turnkey/complete 500HP 440 is about $10,000) random pick EX: http://proformanceunlimited.com/specs/440_475_al.html (I agree with ScoT's post above!) totally forget about HP numbers!!!! focus on building the motor to the maximum amount of TQ ft/lbs possible starting at the lowest possible rpms possible,,,, aka a "RV" or "4x4" motor build which is relatively inexpensive.... it's the amount of TQ force available acting against the weight of the truck that pushes you back in the seat while accelerating for a really fun ride on the street! because the truck is sooooo heavy, you need deep rear gears to multiple the available motor TQ force applied to the tires illustration ex: 500ft/lbs x 2.80 gears=1400ft-lbs twisting the tires/4000lbs of weight=.35 lb of force per lb of wt 500ft/lbs x 4.11 gears=2055ft-lbs/4000 lbs=.51 lbs of force per lb of weight....that's 32%! more force per pound" do note how less weight does help so much 2055ft-lbs/3500lbs=.58 versus .51 =11% more force per lb I don't follow mopar parts pricing much at all but they are not "inexpensive" to build compared to many.... I wouldn't be surprised to see a $5000+ total for a completed 440 RV cam motor drive train swap |
I don't think steep gears and an RV cam are the way to go either. Why rev an engine built not to rev? Doesn't make sense to me. I would go a mild 440 rebuild with a hydraulic cam. Low/no maintenance, plenty of power and streetability. Toss some 3.55 to 4.10 gears in the back with a fairly tall tire, and throw some nitrous at it if you want some impressive times at the track. Cheap, easy, and it will last. |
A shop will charge as much as they think they can charge, you will have to shop around and be specific in what you want and what you are willing to pay. Get a quote in writing, because shops are notorious for inflating prices for "unseen" necessities. A good shop will know what it needs and what it will use. Building it yourself would bring the $3000 easily within reach if you have a core already. And 500hp would be not hard to get IMO. |
Crazy Mopar,
a "RV" cam (ex:204/210) HP rpm's peak is only 4500-4800, not high rpms at all.... a "taller" tire defeats the tq gain of the lower gears ratio..... Fnix, stock, rebuilt and mileage guaranteed 440 complete long blocks are anywhere from $2000 to $4000 so $3000 just for the normal rebuild machine work is likely to much.... |
We had good luck with the 292/.509 Purple Shaft (Mopar performance) in the long ram truck and some cars, but there are better cams out there now.
The 383 truck has a Comp XE268H, Perf RPM, 750. A good cam will have a short 108* LSA (maximum) and duration about 230* @ .050. Be sure and get one ground for the >mopar sized lifters<, not some cheapy cam made with Chevy lobes. Stock heads 440, stock rods, decent pistons not deep in the holes, 727 trans, good 4 tube headers, 1 3/4" preferred, 15 inch header collector extension, (24 inch total collector length), (better is 4-2-1 headers) and a true stall of about 2600-2800, Performer RPM and 750 AVS Edelbrock, 3.55 gears with 275.60x15 tires, ladder bars or clamped springs, 200 pounds back by the tailgate, and it still will be a tire toaster. It should pull well to 6000 but try shifting at 5500. It won't make 500 hp, but probably 440-450. I should get 13 mpg at 60 mph, and still put you back in the seat well. We did a LWB stock head 360 with Performer RPM, 750, that ran 9.0s in the summer time. OH, if you have an externally balanced cast crank 440 engine..... the crankshaft is 13 pounds lighter than the others and will wind up like a 383. Last edited by ScoTFrenzel; 08-19-2008 at 07:36 PM. |
You can toss a 29" tall tire on a 4.10 gear and you'll still pull 3000+ rpm on the highway with 4.10 gears. It's too much for an "RV" cam. I've built some frisky trucks in the past for work trucks, 440s with decent power and 4.10 gears. I kinda bypassed the "RV" cams.... LOL This was my work truck for years....
Crazy Mopar,
yes, for "optimum" hwy truck passing acceleration rate at 60mph a higher HP/TQ peak rpm's cam is likely better if you are at 3,000....(it winds up quicker at mid rpms) yes, the RV cam HP and TQ are going to drop some above 4500 when passing.... but.... the steep gears are multiplying the available TQ by so much it will still accelerate at very close to a higher HP/TQ peak rpms cam....(and have a quicker 0-60mph time) I mentioned the RV cam just for the idea/principle...(max A/F velocity and Hg at low rpms to make max low rpms TQ and stock parts are fine) |
| Hey Mopar Fans.....industrial 440 Question | STATUTORY GRAPE | Engine | 8 | 08-17-2008 02:39 PM |
| 440 question?????? | HemmiGremmie | Engine | 8 | 08-10-2008 04:55 PM |
| dodge 440 | cfs | Engine | 12 | 06-22-2008 07:43 AM |
| What should i do? 440 question | dodgebullitt | Engine | 3 | 05-01-2008 07:16 AM |
| Studebaker dilemna. | Hippie | Hotrodders' Lounge | 31 | 09-04-2007 01:44 PM |
