440 into a 74' Scamp
Hi All,
I am a "young new enthusiast" in the Mopar world, so please forgive my lack of knowledge. I have two questions, is a Plymouth Scamp an A body, and is a 440 a good candidate for it? It is a 74' and currently has 70,000 original miles with a slant six. I don't have the car yet but I have the 440 that a friend has given me. Thanks for any responses. p.s. I am a welder and I have some experience in custom fabrication if there would be a need for modifications to make the engine fit. I don't however want to have to cut out the whole front end to make it work. Cheers, Joe welder |
Well to get started,After you remove the slant6,you will need to find a v8 "K FRAME".Any V8 dart will work(70 to 74,75).Also your going to want to replace thetorsion bars with larger diameter ones.I'd look to find the spec's on a older big block dodge dart.This will help your prodject.Another item you'll want to consider using is frame connectors.Because most mopars are uni-body.Alot depends on what your end use is going to be.Drag racing,hot street use.But any way you look at it,440 is a lot heavier than a slant6 and will produce a lot more power.Good luck,
stefanP |
All in all, that doesn't sound to bad. I think i'll give it a go. This bod seems to be in great shape that's all. No accidents and no rust. Always parked inside and original owner with reciept. She is asking $4000. I may be able to recoup some onthe working slant 6 and drivetrain that's already in there. Thanks again! Cheers, JB |
Check out the link fellow canuck. I've used their conversion mounts and headers. Quality stuff.
http://www.engine-swaps.com/ |
So it looks like the K member itself doesn't need to be replaced, just modified to accept the 440 block and oil pump. Does that spin about right? Thanks again. JB |
Sounds about right. I used their mounts for a 360 in my 64 fury and later a 440 and 727. Fit perfect. Their tri-Y headers are highly recommended. I think you can contact them direct if you have questions. I talked to them a couple times. Good people to deal with.
Good to know that someone is making Mopar engine swaps easier. My friend who is a Mopar fanatic says that the big block in a Demon/Scamp/Dart goes like stink, but is an evil handling piece on the street due to the increased front end weight. He says he prefers a 0.030"-over 360 with a 4" crank, 408 CID.
Well I've got my work cut out putting that 440 into a Scamp. But I Love a challange! And for my first build a challange it will be....but i'm not alone. I've always got you guys and gals to come and lean on when the going gets tough...I hope at least. lol.
Cheers, J |
Aluminum heads and intake will lighten things up a little.
JB |
Centerline HotRodsAndHemis.com "Speed has never killed anyone, suddenly becoming stationary… that’s what gets you." – Jeremy Clarkson Last edited by Centerline; 12-31-2011 at 10:14 AM. |
Anyone know the approx curb weight of a 78' slant six Scamp?
Thanks, JW |
| 71 ply scamp cranks but dies when key is released | Footstomper | Electrical | 10 | 09-09-2007 07:55 AM |
| 360 headers for a 71 Valiant Scamp. | Parisienne66 | Engine | 10 | 06-19-2004 02:34 PM |
| 440 in 1971 Scamp? | Parisienne66 | Engine | 3 | 04-08-2004 08:09 PM |
