440 with a lot of low end torque... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2006, 05:58 AM
I have a 1972 Chrysler New Yorker with 440/727 and 8 3/4 rearend with posi. This engine is rated at 225 hp and a low 8,2-1 compression ratio. I am new into Chrysler and have a lot of questions....I want to know the best way to make this car into a kind of performer. I know it is heavy, but I would like it to do low 13 sek on the strip. I think that I should need around 500 horses to get that goal. I am planning on stroking the 440 to 500 cui. I want as much low end torque I can get, to keep the rearend ratio nearly standard, and as smooth idle as possible. I want to hear about cam selection, which heads to use , I guess that the factory heads on this engine can't do the job - am I right about this?, intake that wil fit under my hood, carb. etc. Any suggestions are appreciated...
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
What holley 750cfm carb to go with ??? FiefSS Hotrodding Basics 17 09-29-2003 03:58 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
