440 mopar question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2006, 10:33 AM
440 mopar question
A friend has a 1970 440 6 pack charger. He is leaking water around the rear exhaust bolt on the passenger side. Do the exhaust bolts go into the water jacket on this motor? I told him to get some sealer and seal the bolt the way you would do a head bolt on a chevy. It has the stock heads.
Old 06-01-2006, 11:05 AM
440 mopar question
454me
The manifold studs go into the water jackets on the heads. You can seal the studs I did it on my 440. I would check the area for cracks , it is not common but possable. Good luck.
OLD HEMI
Old 06-01-2006, 06:12 PM
Crazy Mopar Guy's Avatar
Alot of the time on new engines with a dripping exhaust stud the drip just slowly stops, it seals itself.
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Mopar guys-318 question? el-cid Engine 10 08-17-2005 08:13 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
Mopar 440 options 1meancuda Engine 4 02-02-2002 04:57 AM
