440 on propane - what pistons and cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2012, 03:18 PM
I have a 440 truck engine (out of a winni) from 1973 - low compression from what I have read 8:1 approx - 346 casting heads (88cc)
Engine looks real good only 60,000 original miles
It will be going into a tube buggy and I am looking for good low end torque with a descent mid range power
I want some opinions on my piston and cam choice
I plan on running l2295f (Flatlander Racing - TRW Chrysler Pistons pistons which are dome pistons. From what I have read they should bump up the compression to approx 10:1. Prpoane likes compression.
I am looking at running a comp cam
21-220-4 250XE 21-220-4(Single Bolt) - Xtreme Energy
It says I can't run stock springs with that cam - could anyone recomend springs.
Any advise and opinions would be appreciated
thanks
Old 08-12-2012, 06:08 PM
bigdog7373's Avatar
Of course it's fast
If you scroll down on that page they have the recommended springs on there. I'd use what they say to use.
Old 08-13-2012, 01:04 AM
bsfor
1 don't run propane, it's hard on engines.
it takes big tanks and no one can smoke or
make a campfire within 50 feet of your dune buggy.
2 get your parts from Mancini Racing or
some other Mopar Performance dealer,
it makes things simple to do it right the first time.
have a nice day!
Old 08-13-2012, 01:47 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Pay no attention to the kid..Propane works just fine..and your cam and piston choice will be fine..just some tuning will be needed to run the propane as well as the proper modified carb..
Sam
Old 08-13-2012, 02:09 AM
hello there one more time
L2355F TRW Forged pistons are the 10 to 1 pistons.
that's from memory.
a propane conversion set up is made by Impco
that used to be in Gardena or somewhere.
propane makes the valves run hotter.
one more time, do you know anything about this
or do you just like to play with the keyboard?
have a nice day!
Old 08-13-2012, 08:47 AM
Engines have ran on propane for years and years with no problems. I runs much cleaner and is completly safe if done right.
Old 08-13-2012, 03:17 PM
poncho62's Avatar
Wiki Edits: 5
that's from memory.
have a nice day!
Strike 2..............
Old 08-13-2012, 03:39 PM
propane
i ran propane on a stock 454 bbc for years no problems, mileage was down a little vs gas but lp was a lot cheaper.
Old 08-13-2012, 05:49 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
that's from memory.
have a nice day!
just a fyi mouthing off to a moderator is a good way to get booted.
Old 08-13-2012, 06:09 PM
LATECH's Avatar
Hey Cali kid. You shouldnt open your mouth without your brain engaged...in which case you would know that you dont have a clue what your talking about.
Back in the 80s I had a boss that ran propane in an F250 with a 400 m.
It never had any problems and ran 180,000 miles before he sold it to another guy.
Propane is cleaner on an engines internals, wont dilute motor oil or wash the cylinders dry and scuff the rings.It really is BETTER for an engine than Gasoline. The ONLY thing is you need is to use hardened seats in the heads , but by the time the 80s rolled around , everything had them anyhow.
Honda sells a fully converted civic from the factory that runs on propane As a brand new car. Many fleets use them as it pays them to have there own fueling station and run them as a fleet.
As far as saftey, propane has a aromatic agent added so in the event of a leak, it is easy to distinguish a leak. If a propane tank explodes, it would be from excess pressure, due to heat most likely. If the tank was leaking and the leak was burning, most people would have the sense to get waaaay back. How many times have you seen a propane tank burning?
People who are careless with propane are the ones who have the problems...like filling rusty, outdated, untested tanks, or tanks that failed an inspection. Like with any thing, faulty equiptment will cause trouble , you just have to use your head and keep your equiptment in good shape.
A 440 on propane.....all day long man.
Fact is stranger than Fiction
Old 08-13-2012, 06:28 PM
vinniekq2's Avatar
propane is safe and has a good delivery rate. There is a big block chevelle close to here that runs dual mixers and a turbo with amazing results. The propane doesnt ping like gasoline.The loss of power is due to the lower BTUs in propane,so throw some compression at it and some timing too.
BTW,I use a flame in my BBQ and the propane tank sits underneath the burner,thats less than 50 feet away.
Old 08-14-2012, 05:39 PM
johnnyg's Avatar
hold my beer and watch this!
bsfor
have a nice day!
I drove a forklift for 6 yrs and smoked cigars while driving and never blew up
Old 08-14-2012, 05:43 PM
LATECH's Avatar
you Da Man.
Old 08-14-2012, 07:07 PM
General Martok's Avatar
Propane has octane of 110 (c3h8) molecule
btu output around 91,000 -84000 btu gasoline has about 112000 btus
so your going to use more no daught but you knew that.
Your pistons last time I bought a set of TRW they were heavy weight forged
able to handle NO2,
Your cam is mild 110 lobe seperation is great for big block mopars.
What would work a good set of heads,the heads on the motor home engine
has steam holes for extreme duty and are not necessary,a good set of Eldabrocks aluminium heads would work.
One main thing that always should be done to a BBM is up grade the oil pan and windtray.
High volume oil pump,a must.Pick the RPM you want to run yore motor at
and build for that rpm.
Old 08-15-2012, 09:47 AM
eric302's Avatar
Why be normal?
My employer in the mid 90's had six ford vans, 6 cyl. They were dual fuel (propane and gasoline). The propane tank was mounted in the vehicle and we didn't have any problems with these vans. Also in the past 5 years we started to get quite a few all propane fueled vans. Just my 2 cents worth.
Looking for answers on Cam Dynamics for 440 dragracer63 Engine 1 12-08-2010 08:04 PM
Which cam for supercharged 440 on the street? jamieson Hotrodding Basics 6 11-25-2010 09:51 AM
440 cam suggestions automods Engine 3 10-05-2009 01:43 AM
Cam for 440 Danny Rader Engine 5 11-15-2004 04:24 PM
440 cam 1meancuda Engine 2 10-14-2002 08:17 AM
