45 degree barbed fitting for T-400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2013, 05:11 PM
Hello, I am replacing the hard cooling lines on my TH400 with rubber lines. I would like to know if anyone has come across brass 45 degree barbed fittings that will mate with the inlet and outlet fittings on the transmission case. the hose is 5/16 I.D. approved for transmission fluid. Thanks.
Old 02-15-2013, 06:06 PM
rubber trans lines are not a good idea rubber will rot with oil and dont do well in high heat (exhaust engine heat) they will become soft stretch and rot. if you dont want to spend the money for new prebent lines get some aluminum or soft copper line and a tube bender and flairing tool make your own...........good luck!
Old 02-16-2013, 05:53 PM
45 degree barbed fitting for t-400
hi I talked to my son,he says that they do make special rubber lines with AN fittings for automatic trans hope this clears up any confusion that I may have caused......
Old 02-21-2013, 11:57 AM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
Just be cause you can, doesn't mean you should. Heed the advice. Hard lines are way more durable. No fun oiling down or worse yet catching the thing on fire when, and I do mean when it leaks.
Old 02-21-2013, 12:11 PM
TexasT's Avatar
Old 03-09-2013, 04:45 PM
Last journal entry: 1968 Firebird Resto 8
Ditto on Texas T advise. Don't use rubber for transmission cooler lines... Trust me!
Here are a few links which will help you get the job done correctly.
Transmission+cooler+line+kits - JEGS High Performance
If you can't use steel or copper lines, go with these, Transmission Line Adapters, Aluminum, Black, Male -6 AN to 1/4 in.-18 NPSM and with these you can plumb braided stainless transmission cooler lines with ease.
Summit Racing® Transmission Line Adapter Fittings SUM-220027 - SummitRacing.com
SBC 18 degree head compared to 23 degree head powerwise? sb72elcamino350 Engine 7 03-09-2010 02:01 PM
90 degree threaded fitting for 600 holley? Mad_Max Engine 1 07-26-2008 10:18 AM
trans cooler fittings.. 3/8 hose fitting to a AN fitting? scapegoat Transmission - Rearend 6 04-14-2008 04:12 PM
Using 18 degree pistons in a 23 degree block S10 Racer Engine 2 03-11-2008 03:52 AM
Pressing hoses onto A/C barbed fittings? cboy General Rodding Tech 13 02-06-2008 06:32 PM
