45 degree flaring tool - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2009, 02:41 PM
If any of you guys ever tried to use a cheap flaring tool you'll
know what i'm talking about. It sucks. What's a good brand.
Old 05-13-2009, 05:57 PM
fast68's Avatar
likes chevy trucks & boobies
KD is what we use and theyre ok until they get old
i always use pliers to crank the wing nuts tight on them.
so they grab the tubing good.
tubing double flaring tool kit
Old 05-13-2009, 06:12 PM
1947 Chevy Coupe
Aren't flares 37 1/2 degrees?
Old 05-13-2009, 07:06 PM
AN type fittingd use 37 degree flares others use 45 single or double flares depending on the fitting. I like the tool Snap On sells but the ridged is also a nice tool if you are going to spend the money.
Old 05-13-2009, 07:26 PM
47chevy's Avatar
Last journal entry: Here is the car after paint
I have a mastercool hydraulic flaring tool. Was not cheap, works great. If you do a lot, think about getting one.
Old 05-13-2009, 08:03 PM
Last journal entry: frame build
I have a Snapon and a Rigid and they both work well but mostly I use the one I got out of granddads shop. It is about a inch thich and doesn't rely on serrations to hold the tube and doesn't crush the tube any. No name and have never seen another.
Old 05-13-2009, 08:27 PM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
buggmann
i used the one i got from auto-zone from their loan a tool
it worked OK and it got the job done i just did not want to
buy one i used it for my brake and gas line
Old 05-18-2009, 09:50 PM
New Member
What 47chevy said. Mastercool all the way. Not cheap, but worth every penny.
Tips for shop layouts and tool purchases. schnitz Garage - Tools 9 10-18-2010 11:19 PM
Brake Flare Tool Compromise S10 Racer Garage - Tools 3 03-26-2009 07:21 AM
blaster vacuum 71corvette Body - Exterior 6 12-23-2007 07:24 PM
Flared Fittings 37 Deg Vs 45 Deg leejoy Engine 9 01-02-2006 10:35 PM
