451m/400 budget build - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2010, 08:20 PM
Here are my plans. I would like to build a street 400 to put back in to my 72 ford ltd with 57,XXX. looking to not go over around $1500 mark. From what i have gathered the cr was horrible in these engines from the factory. To fix this i was thinking of putting a set of aussy 2v or 351 c 2v heads on it. Which would fix the cr problem. but any ideas on what the cr would be with either of those heads on it? next what would be a good street cam. The final question i guess would be to rebuild the block itself. Would i be able to get away with just using a regular rebuild kit if every thing shows normal wear?
Old 07-18-2010, 08:54 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.projectbronco.com/Technic...e_build_up.htm
Old 07-18-2010, 08:57 PM
I have read that one. But thank you.
Budget 400 SBC build up elcamino74ss Engine 15 02-02-2011 08:22 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
350 block/$2000 budget/forum build American Muscle Hotrodding Basics 19 01-26-2009 09:15 AM
budget 350 build ideas. need critics.. 74chevyflat Engine 7 06-11-2006 08:29 PM
Best coilovers on a budget build? staleg Suspension - Brakes - Steering 10 01-07-2006 02:13 PM
