454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2008, 06:43 PM
I just traded some brodix-10 heads for a 454 and i need specs please. I have searched and searched with no luck on hp and tq numbers. Here are all the numbers ive found on the blocks and heads.
Block:12550313, l048, Mark 5 H2, 048, gm-0, timing chain cover 10230953
heads: 10114156, I think "CIt or C1T" , ko68
Intake: Team G
Carb: 750 holly Dp
Also is there a site were i can find a interchange chart for this engine.
Thanks,
Chad
Old 08-16-2008, 07:06 PM
327NUT's Avatar
Mortec.com shows the block and heads as Gen V '91- up 454 crate engine.
block is 4-bolt, heads are open chamber oval port 118cc......
Old 08-18-2008, 01:22 AM
I used dyno2003 and it said with headers and mufflers it has 303hp/397tq does this sound right?
Old 08-18-2008, 08:49 AM
Depends on what engine specs you used (cam, cr, ect).
Low performance 454's are very weak from the factory. 275 hp and 350 ft-lb can be very possible. However, these engine's come alive with some simple bolt-ons.
A 7.5:1 cr 454 with a mild rv cam (202/210 at 0.050"), a set of headers, 4bbl carb, and 049 or 781 heads should make 340 hp at 4500 rpm and 475 ft-lbs at 3000 rpm.
Old 08-18-2008, 10:20 AM
The block is a gen v block so im limited to heads. I was told by the guy i bought the engine from said "that any head will work from a 454". But i did some research and so as of right now im stuck with stock heads.
Old 08-18-2008, 11:32 AM
I'm not 100% sure, but I think you can use gen iv heads on a gen v engine. But it doesn't matter. A mild cam, headers, dual plane 4bbl intake, and 4bbl carb will make nice gains even with stock gen v heads. Try that with your dyno software.
Old 08-18-2008, 11:44 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
This thread may help
Rich
Where can i find hp heads for a gen v 454
Old 08-20-2008, 10:15 AM
I have to get alternator brackets, power steering bracket, and pump. Does all 454 brackets fit any year? the engine is a 91-95 crate engine.
replacing a 454 with a 350...... Treozen Engine 8 03-05-2008 01:28 PM
5.0 to 7.4 swap Tilar Engine 7 02-09-2008 06:51 PM
454 into 427 Alan Byers Engine 22 01-18-2008 12:36 PM
Squeezing a little more power out of my 454 RObs71Nova Engine 8 05-21-2005 03:38 PM
454 or 427 for 70 Chevelle? f100beatertruck Engine 3 11-25-2003 05:29 PM
