454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2008, 10:09 PM
In my backyard i have a late 70's early 80's bus with a 454 in it, will it work if i put it in a 70's chevy truck or will it only run with a bus set-up, is it worth rebuilding?
Old 10-13-2008, 10:34 PM
Sickpuppy22's Avatar
Pull it and find out, if its not cracked and hasnt been opened ( or if you know it still runs) get it checked out by a machine shop, never waste a 454 especially when its free
Old 10-13-2008, 11:06 PM
Most GM big trucks and buses had 366 or 427 tall deck engines in them! You might want to check the casting #'s on the bellhousing before you go to a lot of expense thinking its a 454....
Old 10-13-2008, 11:35 PM
ok, thanks for the input, appreciate it
replacing a 454 with a 350...... Treozen Engine 8 03-05-2008 02:28 PM
5.0 to 7.4 swap Tilar Engine 7 02-09-2008 07:51 PM
454 BBC heads by FoMoCo?? WakBordr7387 Engine 9 06-13-2006 11:30 PM
Squeezing a little more power out of my 454 RObs71Nova Engine 8 05-21-2005 04:38 PM
454 or 427 for 70 Chevelle? f100beatertruck Engine 3 11-25-2003 06:29 PM
