454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2013, 05:25 PM
car will not idle without vacumn advance hooked up do i need change something in distributor brand new msd distributor 527 lift cam 10-1 compression quickfuel carb 750
Old 01-01-2013, 05:28 PM
have 22 degrees at idle without vacumn advance when i can keep it idling idles about 1100-1200 rpms seems to be a little high to me
Old 01-01-2013, 10:44 PM
454
Checkout this article. It explains how to set-up your distributor, timing, and a litle about your carburetor. http://www.crankshaftcoalition.com/w...EI_distributor
BBC 454 Mark 4 heads going on a 454 Mark 5 block? c65shoebox Engine 2 03-14-2012 10:03 PM
454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 heathj1 Engine 2 12-21-2008 11:22 AM
454 ss in a 57?? alllaser General Rodding Tech 8 07-06-2006 12:16 PM
454 BBC Vs. 454 SBC differences and why...? Bumpstick Engine 4 11-02-2005 01:26 PM
454 H.o. 79 Malibu327 Engine 4 03-16-2004 12:11 AM
