454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2008, 07:25 AM
heathj1's Avatar
Which way to the swap meet??
I have a 454 289 block 2bolt I know where there is a 454 4 bolt 1 piece seal long block I can get for $250. Which block would be better for a 496 build 10:1 compression 850 Barry Grant ported 049 heads 6500 rpm max going in a g body olds.
Thanks
Old 12-21-2008, 10:15 AM
BOBCRMAN@aol.com's Avatar
Either one will work. The early block is plenty strong for a street motor. Sheet metal is easier to get for the early block. If you are worried about the two bolt mains.Don't.. If you must. Just install aftermkt studs and built that thing..
My shop builds plenty of the 4.25stroke street/drag motors and most are two bolt.
Old 12-21-2008, 10:22 AM
coldknock's Avatar
I'll second Bob. Our race truck has a 496 that makes enough steam to run 6.0 in the 1/8th and it's a two bolt main block.
Larry
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Chevy Small Block Seal and Pan Problem?? 89SDime Engine 1 07-12-2006 09:32 PM
rear oil seal help alrobjr Engine 5 01-24-2006 07:12 AM
need some input on ford one piece to two piece seal conversion 357ford Engine 6 10-08-2004 10:51 AM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
