Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 or 427?
Thread: 454 or 427?
Old 04-02-2012, 09:54 AM
my87Z's Avatar
my87Z my87Z is offline
Veteran/Firefighter-Paramedic
X2,
you can buy a cast steel 4.250 crank, use stock size 6.135 rods, but you will have to get pistons with a shorter compression height, the cost difference between building a 427, 454, or a 496 is very minimal, like a couple hundred dollars. you go and build a mild 496 and your buddy will be wishing he had done the same.
