Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 or 427?
Thread: 454 or 427?
Old 04-02-2012, 10:50 AM
schottout schottout is offline
you can get a 496 stroker kit from summit from 1400 to 2200 yes some are even higher but your not building a race car the kits have a stroke of 4.25 bore of 4.31 and a rod length of 6.385 i would say use this length rods over a 6.135 length the longer rod give you a shorter piston that is lighter which putts less stress on the piston skirts find you a suitable cam for your application and use and you will have plenty of tq and hp if you wanted to get even more you could change heads or port yours also you could port math your intake to the heads and is easy to do yourself to gain a lil more
