-   -   454 or 427? (http://www.hotrodders.com/forum/454-427-a-217692.html)
Mr.Sec 04-02-2012 09:37 AM
454 or 427?
I've got a virgin 2 bolt main 454 block, it needs to be bored I figure I'll go 30 over. My friend tells me I should build a 427 out of it which is what he uses in his racing truck, I'm not going to be racing my truck it is mostly a daily driver and tow vehicle so I'm looking for better torque and horsepower numbers which one will give me better numbers without spending a mass amount of money?
ap72 04-02-2012 09:42 AM
There's no reason to go 427. if anything go 496.
matts37chev 04-02-2012 09:53 AM
x2^^^^^^go bigger, not smaller
it will cost about the same for parts if you only have block
but you will need to clearance it for the extra .25" stroke
my87Z 04-02-2012 09:54 AM
X2,
you can buy a cast steel 4.250 crank, use stock size 6.135 rods, but you will have to get pistons with a shorter compression height, the cost difference between building a 427, 454, or a 496 is very minimal, like a couple hundred dollars. you go and build a mild 496 and your buddy will be wishing he had done the same.
Mr.Sec 04-02-2012 10:31 AM
What components do I need to make a nice 496?
cdminter59 04-02-2012 10:40 AM
496 rotating assembly
I was looking on Ebay and found this rotating assembly. Check out http://www.ebay.com/itm/Eagle-Rotati...#ht_1614wt_952 Not a bad deal which includes everything.
schottout 04-02-2012 10:50 AM
you can get a 496 stroker kit from summit from 1400 to 2200 yes some are even higher but your not building a race car the kits have a stroke of 4.25 bore of 4.31 and a rod length of 6.385 i would say use this length rods over a 6.135 length the longer rod give you a shorter piston that is lighter which putts less stress on the piston skirts find you a suitable cam for your application and use and you will have plenty of tq and hp if you wanted to get even more you could change heads or port yours also you could port math your intake to the heads and is easy to do yourself to gain a lil more
matts37chev 04-02-2012 12:13 PM
from the homework I have done, I would stay away from the eagle cranks (rods are ok), use a scat crank instead
Blazin72 04-02-2012 12:33 PM
My vote is to stick with the 454. It'll make more torque than the 427 and burn less gas than a 496. After all, he said it's his daily driver.
ap72 04-02-2012 01:39 PM
the mileage difference between the 3 engines will be VERY minimal as most street driving is NOT done at WOT. A 454 is adequate, but a 496 is better.
Blazin72 04-02-2012 04:47 PM
Just adequate? Unless the OP is planning on hooking up to a really big trailer then the 454 is MORE than adequate. If he is hooking up to a huge trailer then he'd be better off with a diesel. Either way, I stand by my recommendation of sticking with the 454.
The thing I see on this forum is that people (myself included) often try to pursuade posters to go bigger and bigger and bigger, even if it's not needed. In this case if it's a daily driver pulling a moderately sized trailer on occasion then a 454 will do just fine and save a little bit of gas in the process.
starnest 04-02-2012 05:50 PM
If your going to build this you'll need a good machine shop to service your block. If you are patient and shop, you should be able to find servicable stock crank and rods (maybe even pistons). Just include the cost of having them serviced in the price you pay. These will be much less than buying all new parts (especially since the other guys are scrapping the stock parts to build 496 engines). BTW - the shop I use specializes in bbc so he has a lot of used parts ready to go at very reasonable prices.
I used the 30 over pistons in my 454, so I bought those new, my shop pinned them for me, and balanced everything from damper to flexplate.
Building a bbc isn't cheap, but for a good truck engine you don't need high priced high performance parts to get great torque, good horsepower, and less than desired fuel economy.
Not that I don't enjoy a totally wild over the top engine build, re: the v24-71 on the favorite engine pic thread,
Bowtie man 04-02-2012 06:00 PM
Any of those three would do the job.
matts37chev 04-02-2012 08:48 PM
I went with the 496 because....
for me, it only cost a little more to buy the new rotating assembly (with floating piston pins, that I can assemble)
than the price of having my old stock 454 crank -checked, turned
rods checked, resized, and pistons hung
now I have spent all my money on new, better parts I can assemble
instead of spending all my money on getting my old 1/2 worn out parts checked and modified
just my $0.02
Mr.Sec 04-02-2012 10:01 PM
Thanks guys, I'm mostly a small block guy my suburban currently has the stock tbi 350 that was converted to a 625 edelbrock carb it's a decent engine but it's an absolute dog when I try to tow anything. I'm on a racing team so I tow full size chevy trucks to various racing events. Having never built a big block before I figure this will be a good learning experience. although from what I hear dollar for dollar a small block is better, having heard that I'm still going to build this big block just because I haven't yet. Hopefully I'll be pleasantly surprised. Being budget minded it seems like a little better than stock rebuild with a 30 over bore is the way to go.
