454 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2005, 06:25 PM
Derkyb's Avatar
454 ?
I found a great deal on a 454 4 bolt block, but it had a wristpin come out a put a groove in the cylinder wall the length of the stroke. How far can you over bore a 454 and is there such thing as a tall deck 454? Also if it cant be bored can it be sleeved, has anyone sleeved a block?
Old 03-18-2005, 08:27 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Yes their is a tall deck 454.
You can bore to at least .060
Old 03-18-2005, 08:53 PM
BOBCRMAN@aol.com's Avatar
Just have the block sleeved. I have sleeved dozens of big blocks. A proper installation leaves you with a cylinder wall stronger than the block. The sleeve material is usually a better grade of iron.
Old 03-18-2005, 09:12 PM
predator carb guru's Avatar
Mark Goulette
depending on the use, you can bore a 454 to about .100 over, but you'll need at least a half fill on the block. for street, i wouldn't go over .060. as far as tall decks are concerned, gm never produced a 454 in the tall deck version. all the 454's were standard deck, or 9.8". the tall deck motors that were produced were truck motors, with a deck height of 10.2", and came in 366 ci and 427 ci. although the 427 had the same bore as the 454, it only came with the 3.76" stroke crank that the 366 had. the block was not factory clearanced for the 4.00" stroke crank that the 454 was, but can be made to fit with a bit of grinding. for performance use, you'd be better off with a 454. also, my experience with the tall deck truck motors is that they have thin cylinder walls to begin with. big overbores on them isn't a good idea. one other downside to them, is that they weigh more than standard deck blocks do. not a whole lot, but some. while they can be built up for performance use, i'd limit the overbore, keep a short stroke, and run a really long rod. i know someone will disagree with this, but i believe there are alot better blocks out there for racing/high performance use.
Old 03-19-2005, 11:26 AM
Wiki Edits: 49
Originally Posted by predator carb guru
......as far as tall decks are concerned, gm never produced a 454 in the tall deck version. all the 454's were standard deck....
This is incorrect. Chevrolet produced more than one tall deck 454. As an example, casting number 10134366 is a 454 4-bolt main Bowtie tall deck block as are casting numbers 14044807, 24502506. There are probably others as well that are of the 2 bolt main variety.
Centerline
Old 03-19-2005, 12:59 PM
Mark Goulette
ok, got me on that one..............i was brain dead at the time of my last post. i didn't even think of the bowtie blocks. thanks for the correction. dang, i feel like an idiot now...................sheesh!!!
Old 03-19-2005, 07:45 PM
Derkyb's Avatar
Thanks for the info guys especially clarifying the tall deck question. I've heard so many people say there wasnt a tall deck 454 and a few that say there is. I think I will purchase the block and have it bored and stroke to a 496, should be more than enough to a 502. Any good combos for a 496?
Old 03-20-2005, 11:03 AM
Wiki Edits: 49
Not to worry. With the myriad of parts available now days its hard to stay up to date.
Centerline
402 vs 454 ROBBYLEE25 Hotrodders' Lounge 8 09-01-2004 10:43 AM
454 engine swap Hot_Rod_Faith Engine 1 01-15-2004 02:30 PM
454 or 427 for 70 Chevelle? f100beatertruck Engine 3 11-25-2003 05:29 PM
Seems Best way to Buy a 454 BB is to Buy a Truck Auto-Part Engine 3 11-15-2003 04:23 AM
454 ID I_3putt Engine 2 03-02-2003 12:40 PM
