454 in 65 impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2011, 01:44 AM
hotrodcommuter's Avatar
TX plates, CA license
454 in 65 impala
You all will be happy to know my wife and I stayed up putting a 454 I bought, formerly in a 90 chevy truck, into my 65 impala, only to find the oil pan didn't clear cross member. Does anyone know if I can buy the oil pan for the 65 impala 396? Also, do I need to buy a different oil pump as well?
This motor has a one piece rear main if that makes a difference.
Old 04-01-2011, 02:23 AM
ericnova72's Avatar
More for Less Racer
I believe I have seen mention that the truck pan will not clear car crossmembers and/or steering linkage will hit the pan when turned close to full left or full right.
Moroso, Milodon, Canton, Kevko, and Hamburger are all brands to look into. Check with Impala resto parts suppliers also.
After doing some looking on Ebay just for pictures, it is easy to see where the offending part of the truck pan is, you may want to look just to familiarize yourself with the needed shape.
You can't use a stockpan for the stock 396, it has the wrong shape for the 1-piece rear main seal you block has. You'll have to search for a car style pan for the 1-piece seal block. Oil pump won't need to be changed, but the oil pick-up might depending on the depth of the new pan.
One that looks like it will be what you need is Moroso #20411, fits Gen V/VI(1-piece seal) into '64-72 car, 6 qts, 8" deep. This is a widened sump performance pan, I don't know if you will be able to find a stock sump type pan if that is what you want. You'll have to search.
65 impala ss haguilar79 Transmission - Rearend 1 05-28-2009 04:34 PM
WANT TO TRADE? LHD 64' Impala dash for RHD 64' Impala Dash garagedoreen Interior 1 11-18-2007 07:55 AM
my 62 impala!!! 383silverado Engine 0 06-14-2007 10:23 PM
Switching 63 Impala to 64 Impala heat control dmaggard Interior 2 09-13-2006 07:17 PM
68 Impala SS Gerhead67 Hotrodders' Lounge 1 11-20-2001 03:39 PM
