454 in 65; what mounts? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-27-2011, 11:37 AM
hotrodcommuter's Avatar
TX plates, CA license
oil pan already changed. Yes, different bolt hols are for the 6 cylinder, not my issue. The issue, I have found at 2 in the morning, is that there are 3 different style of motor mounts; they differ in width, I happened to get the ones that are a little narrow for my supports. So I am going to autozone this morning to see the measurements of 409 mounts........I will let you know, but basically, the width on the mount(inside dimension), should be 2 5/8 in. And they should be the 'tall' mounts for the big block.
So I think...............(that seems to be part of the problem)
  #17 (permalink)
Old 06-28-2011, 03:19 PM
Update; Autozone's part numbers are not consistent with what's in the boxes!
so I ended up with 1965 impala 409 mounts that are 1/4 in too wide for supports, but will work, I think. They need to be shimmed alittle, so I will hunt down spacers, I have two, I believe I will need two more.
Tri 5 mounts tom4040us General Rodding Tech 3 08-10-2010 01:42 PM
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 09:52 AM
Air Bag Mounts H2Os50 Suspension - Brakes - Steering 2 03-14-2005 05:56 AM
Do I need new mounts? 60'Panel Transmission - Rearend 1 01-13-2003 05:55 PM
i need mounts from a 2.8 to a 305 dalcowboys98 Engine 5 11-16-2002 02:59 PM
