454 in 65; what mounts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2011, 02:26 PM
hotrodcommuter's Avatar
You guys have been very helpful, but I'm at another brickwall;
I am putting a 454 in my 65 impala, I am using 396 exhaust manifolds. I originally tried to use the 327 mounts, they make the motor sit too low and it exhaust manifolds hit steering box. So from advice here, I ordered '69 396 engine mounts. They are too narrow to 'seat' on the engine supports. I cannot modify them without ruining them. Any ideas?
Old 06-26-2011, 03:21 PM
T-bucket23's Avatar
Wiki Edits: 26
There are basically 2 types of mounts. Tall and narrow and short and wide. The frame mounts need to match the engine mounts. You need to get the corrcect set of frame mounts
Chet
Old 06-26-2011, 03:22 PM
I appreciate you effort to help, ad I don't mean to be rude, but that's why I posted; I am trying to find the right mounts to use.
Old 06-26-2011, 05:22 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Go to this link, it may answer your question.
http://www.pozziracing.com/camaro_engine.htm
Old 06-26-2011, 05:23 PM
mounts
order 65 impala 396 mounts
Old 06-26-2011, 06:20 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Probable that you will also need 65-6 Impala 396 exhaust manifolds as well
Old 06-26-2011, 09:35 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
hi, im not trying to be a smart a** but the big block frame mounts dont sit in the same spot as the small block ones if you look at the cross member there are two sets of holes i didnt know if you were aware of that so i just wanted to mention it. keep checking on ebay for 65-66 bb frame mounts they should show up on a fairly regular basis.
Old 06-27-2011, 06:33 AM
T-bucket23's Avatar
Wiki Edits: 26
I think a lot of the trucks used the tall mounts.
Chet
Old 06-27-2011, 06:53 AM
life is a temporary assignment
I don't see where that's different... A big block will bolt up right where a sbc was... There's no difference... The only difference between the big and small block is from the mount's forward.. It should fit right where the small block was..
Old 06-27-2011, 07:04 AM
helrazr3's Avatar
my cross member has two sets of holes unless they are for a 6 cyl. there must be some reason for them
Old 06-27-2011, 07:11 AM
OK !!! I use a sbc block to mock up my 41 willys frame,,(And any other frame I build for a big block),, With the same mount's,, I then dropped in my big block .... Where's the difference ????
ID:	56397   Click image for larger version
Old 06-27-2011, 07:25 AM
helrazr3's Avatar
i agree with you, i never built a big block so i made the mistake of assuming that is why there are two sets of holes so the fact that i do have two sets of holes must be to mount a six cyl. 250. but again thats a guess.
Old 06-27-2011, 07:32 AM
I hear people all the time say the same thing.. (I had to move my mounts on the frame for the big block...) I don't see where there would be a difference...I show the proof right here..
The only way I can see there might be a difference is,, If it's a tall are short mount... Then that ''MIGHT'' make a difference... But when using the same mount, It should fit in the same place...
Old 06-27-2011, 08:10 AM
T-bucket23's Avatar
Wiki Edits: 26
He needs to use the taller style mount for clearance. The frame piece of the mount is different for the taller mount. The distance between the tabs with the bolt holes for the through bolt is shorter on the tall mount. 2 5/8 for the short mount vs 2 3/8 for the tall mount
Chet
Old 06-27-2011, 09:02 AM
Bryan59EC's Avatar
6cylinder frame mounts are different.
My 454 dropped right into the v-mounts on the 59 (way before the 396 came)
Some cars do use different frame mounts for the BBC, but the mounts do not relocate the engine. On the Chevelles, the mounts provide a tab to keep the engine in place should a mount break loose.
Other than that--should go right on in there with SBC mounts
The oil pan may need to be changed to a shallower 4-qt pan for frame x-member clearance tho
Tri 5 mounts tom4040us General Rodding Tech 3 08-10-2010 01:42 PM
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 09:52 AM
Air Bag Mounts H2Os50 Suspension - Brakes - Steering 2 03-14-2005 05:56 AM
Do I need new mounts? 60'Panel Transmission - Rearend 1 01-13-2003 05:55 PM
i need mounts from a 2.8 to a 305 dalcowboys98 Engine 5 11-16-2002 02:59 PM
