454 in a 66 el camino - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2010, 09:04 PM
truckboy61's Avatar
Would it be difficult to place a 454 in a 66 ELCY that has a 327 ?
Old 06-05-2010, 09:09 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
'66 Chevelles came from the factory with 396 BBC motors. All the stock parts to do your swap are on somebody's shelf, waiting for your phone call.
Old 06-05-2010, 09:14 PM
fourspeedwagon's Avatar
6 reps of 12oz curls
Last journal entry: 65 SS Project
Not at all. I just put a 454 in a 64. The frame horn (motor mounts) I didn't even have to change. Headers for the big block, block side motor mounts, and barely anything else. My radiator had the top inlet to one side so a water neck with an angle, mines a 4 speed, so I needed a slightly longer clutch pushrod. Easy as pie! DO IT!!!
64s didn't even come with big blocks from the factory- yours (66) was a regular option.
What transmission are you using?
If your radiator is only a 2 row I would upgrade that.
Old 06-05-2010, 10:41 PM
truckboy61's Avatar
It has a t350 but I got a power glide in my garage I was thinking about putting in is the 350 better suited ?
Old 06-05-2010, 10:45 PM
Senior Curmudgeon
Wiki Edits: 326
Ummmm, no, a TH400 is better suited.
Old 06-05-2010, 11:13 PM
327NUT's Avatar
A powerglide!!!! I've got an old Dynaflow you can have.
Old 06-05-2010, 11:50 PM
skull's Avatar
tired and retired
Last journal entry: mock up on chassis.
rearend
if ya put in a big block the 10 bolt WILL NOT hold up
when ya floor it or launch hard, ya'll scatter that weak puppy all over the street. l been racing and street building 1966 chevys since 1978 and have wasted 10 bolts with built small-blocks. get a 12 bolt or a 9'' ford.
Later
Old 06-06-2010, 12:32 AM
truckboy61's Avatar
Any suggestions regarding make and model to get rear end our of that will fit in smoothly ?
Old 06-06-2010, 12:45 PM
skull's Avatar
tired and retired
depending on your'e budget, there is a couple company's that make 9'' ford
housings set up for the coil set-up. try criagslist or the internet for a 1964-1967 chevelle/ elcamino 12 bolt, those are direct bolt ins. 1968-1972 rear-ends are wider, but will work with the right offset wheels and narrower tires.
also any A-body GM product rearend will interchange. pontiac, buick, olds.
Later
Old 06-06-2010, 04:21 PM
If you can or have someone help, an 8.8 rearend from an Explorer would work nice too. 96 and newer are disk brakes, most have 373 gears and limited slip- plus they're cheap and available. I wouldn't use one for a drag car, but it'll do better than the 10 bolt, especially if your just running street tires. And ditto what Tech Inspector and the Skull from the wrong side of the state said about transmissions.
Name:	PUG WITH CAKE.jpg
1978 El Camino (GM version) vance pointer Introduce Yourself 3 12-15-2009 11:18 AM
El Camino/ neutral safety switch stinky jinx Electrical 4 03-15-2005 10:00 PM
1978 El Camino SS Weimer Hotrodders' Lounge 8 02-09-2005 04:46 AM
Finding 72 El Camino Disc Brakes sb72elcamino350 Suspension - Brakes - Steering 2 03-19-2004 06:35 AM
64 el camino brake conversion camino_man Suspension - Brakes - Steering 0 01-30-2004 06:01 PM
