Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 07-19-2004, 09:24 PM
72novaman 72novaman is offline
454 B.B. into 1972 Nova w/ a 250 I-6
I was wondering what all I need to get to drop a 454 into a 1972 Nova w/ the original inline 6. I know that I need stiffer springs, but what all will be needed?
Thanks for the help.........
Old 07-20-2004, 03:48 AM
jimfulco jimfulco is offline
re: 454 B.B. into 1972 Nova w/ a 250 I-6
Motor mounts & frame brackets for the BBC
Turbo 400 crossmember if you're planning on using a T400
Bigger radiator
Fan shroud
Disc brakes would be nice if it doesn't have them already
Subframe connectors if you're gonna drive it like I would
Old 07-20-2004, 06:13 AM
Beenaway2long's Avatar
Beenaway2long Beenaway2long is offline
or Jeff, or Doc, or...
heavy duty tierod ends and drag link
Old 07-20-2004, 01:42 PM
Bigger radiator
Fan shroud
That all sounds good, but as for the TH400, I'll prob. be going in the direction of a manual 4-speed, or something of the sort, what do you all think would be a good transmission setup for an aggressive street car?
Old 07-20-2004, 04:38 PM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
Big Block Novas had a different heater core also.
The right head will hit the water outlets coming out of the firewall.
Deuce.........General Rodding Tech Moderator
I went to the school of hard knocks ...
where the tuition is high but the retention is exceptional !
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
