454 bbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2010, 09:52 PM
454 bbc problems
having problems with my big block i just built. im holding 50 pounds of oil pressure and pumping oil everywhere except out of my pushrods and am hearing a slight clanking . can anyone help?
Old 06-24-2010, 08:45 PM
454headache's Avatar
This is a wild guess, but I'll take a shot....
1) Every pushrod is plugged so no oil is coming to the rockers. (DOUBTFUL)
2) Every lifter is plugged so no oil is going to the pushrods. (JUST AS DOUBTFUL)
3) An oil galley is plugged that sends oil to the cam and everything else on top. I think this is the culprit. Somebody else will have to chime in on the exact galley. The reverse could also be true but doubtful, that oil is coming to the cam, but draining too fast back down in the wrong place for it to oil the cam, rods, and then rockers.
Yours cam, lifters, or rockers might be toast. But your bottom end should be fine, as that gets priority oiling in pre-GEN 5 BBC's. Worst case is a new cam, lifters, and rockers.
Remember though, that oil pressure is just a measurement of resistance, so high psi could be due to the fact that the oil just can not get to the top of the engine for some reason.
Old 06-24-2010, 11:01 PM
454 bbc problems
very helpfull , so would u recomend stripping to bare block and checking all oil galleys. Also i can prime with drill and get same amount of oil as when its running which isn't much not squarting like should out of pushrods. Its probly a 500 horse bb with 427 closed chamber heads.I check the pushrods and they are only 5/16 rods (might need biger).also i have hydrolic cam and lifters should i go solid lift or stay hyd. . thanks for the help
bbc 454 flexplate and clutch set up? dman16 Engine 7 03-15-2009 01:38 PM
454 BBC heads by FoMoCo?? WakBordr7387 Engine 9 06-13-2006 10:30 PM
Looking to buy a used 454 BBC What to look for old-bill-t Engine 12 05-15-2006 11:32 AM
402 to a 454 BBC what fits old-bill-t Engine 1 05-06-2006 09:26 PM
454 BBC Vs. 454 SBC differences and why...? Bumpstick Engine 4 11-02-2005 12:26 PM
