454 bbc or 355 sbc - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-03-2013, 01:52 PM
cal1320's Avatar
I used a F100 9" rear from a 79 or 80 pickup. Shortend one side 3" to center the pinion. Made it 60" overall. Welded the stock mounts to it and it worked great.
  #17 (permalink)
Old 02-11-2013, 12:36 PM
496CHEVY3100's Avatar
Big boys wear Bowties
Last journal entry: ,
Originally Posted by 454C10 View Post
Find out the cam specs for the 350, as it might require a converter and gears which can add another $1500 to the project.
A stock 700r can't handle much more than a stock 454. Be careful.
A BBC will get around 25% less mpg as a sbc, if that is a concern.
The sbc engine your friend has is worth much more than 1000. Buy the engine and sell it for 2500 then put the money towards the BBC. (aluminum edelbrock heads and intake).
What heads are on your 454?
The stock 454 w /od will probably get better mileage than the Built 350 with the Carb & converter and gears he would have to run . Just my opinion
BBC 454 Mark 4 heads going on a 454 Mark 5 block? c65shoebox Engine 2 03-14-2012 09:03 PM
454 bbc nova111 Engine 2 06-24-2010 11:01 PM
454 bbc h.p sheltonk7 Engine 2 08-12-2009 05:28 PM
454 bbc dboyett38606 Engine 16 01-26-2007 09:13 AM
454 BBC Vs. 454 SBC differences and why...? Bumpstick Engine 4 11-02-2005 12:26 PM
