454 bbc h.p
my buddy has a 454 he thinks is over 400 h.p i dont think so what do you guys think it is a .30 over flat top,109 cc heads,lunati vodoo cam 286d 572 lift,roller rockers,weiand intake,750 d.p,headers,stock dist, also it has not had any machine work such as zero deck or anything he says it is 10.0 to 1 compression but i dont think so it sounds good but revs really slow i think cam is killing it
Not enough information to know for sure.
For example, my 454 motor at 30 over: Bore 4.2810 Stroke 4.0000 Rod Length 6.1350 Int Valve 1.88 Exh Valve 2.19 Head Volume 113.0000 (cc'd 114 to 122) Cam 11-208-3 CB 280H-10 Dur@.006 280 Valve Lift 0.5200 Intake CL @ 106 Int Open 34 Int Close 66 Exh Open 74 Exh Close 26 Dur@.050 230 Lobe Lift 0.3063 Lobe Sep 110 Piston (cc) -25.50 KB 257 Using Weind Stealth manifold with 770cfm carb Hooker Competition headers and flowmaster exhaust According to simulation software: rpm tq hp 2000 490 185 2500 490 235 3000 525 300 3500 565 375 4000 585 445 4500 590 510 5000 585 555 5500 540 565 6000 500 560 6500 395 495 7000 320 430 The cylinder heads are 820 castings with the large 2.19/1.88 valves, assumed is that the valves are installed correctly so that flow is not impeded (shrowded). I think the simulation is overly ambitious, but I really do expect to see >500HP at the flywheel. Based on the info you provided, I think that 400HP is no problem, unless the heads are "peanut port" castings. Those heads make good low rpm torque, but run out of breath after 4000 rpm. These heads may explain why it revs slow, but other factors, especially timing can cause that too. Nothing wrong with letting your buddy thinks he has 400HP, unless he's betting the farm.
| 454 BBC heads by FoMoCo?? | WakBordr7387 | Engine | 9 | 06-13-2006 10:30 PM |
| Looking to buy a used 454 BBC What to look for | old-bill-t | Engine | 12 | 05-15-2006 11:32 AM |
| 402 to a 454 BBC what fits | old-bill-t | Engine | 1 | 05-06-2006 09:26 PM |
| BBC 454 combo | NOlowrider | Engine | 3 | 03-28-2006 05:26 PM |
| 454 BBC Vs. 454 SBC differences and why...? | Bumpstick | Engine | 4 | 11-02-2005 12:26 PM |
