Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 BBC heads by FoMoCo??
Old 06-13-2006, 04:50 PM
WakBordr7387's Avatar
WakBordr7387 WakBordr7387 is offline
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Im gathering parts for a 454 build Im planning right now.
I was given these 454 heads by an old guy Im good friends with. They came off of a Marine 454 (a crusader I think). It was a Higher output 454 rated at 400hp, where as the typical marine 454 is rated at 330hp.
The guy needed new valve guides and put swapped these out for some new GM factory.
I was looking these heads over trying to get the casting numbers off of them. Well I haven't been able to match the numbers up to anything off of the internet, and whats wierd is they are stamped with FoMoCo? is that as in Ford motor company?
Heres the numbers off of them
3030 302
Brad
ID:	12756   Click image for larger version
ID:	12757   Click image for larger version
