454 BBC heads by FoMoCo?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2006, 04:50 PM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Im gathering parts for a 454 build Im planning right now.
I was given these 454 heads by an old guy Im good friends with. They came off of a Marine 454 (a crusader I think). It was a Higher output 454 rated at 400hp, where as the typical marine 454 is rated at 330hp.
The guy needed new valve guides and put swapped these out for some new GM factory.
I was looking these heads over trying to get the casting numbers off of them. Well I haven't been able to match the numbers up to anything off of the internet, and whats wierd is they are stamped with FoMoCo? is that as in Ford motor company?
Heres the numbers off of them
3030 302
Brad
ID:	12756   Click image for larger version
ID:	12757   Click image for larger version
Old 06-13-2006, 05:42 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I am not up on marine heads, but they don't look like any BBC heads I have seen. Is the source confused? Sure look like Ford to me.
Old 06-13-2006, 05:52 PM
Gone fishin'
Wiki Edits: 2
I was told those were off of a 454. I didn't pull them or anything. They were just given to me because they were just sitting around getting rusty, and the guy knew I was working on a 454.
Im not familar with fords, and Im still used to the damn SBC.
Brad
Old 06-13-2006, 06:16 PM
Guy Hiltz's Avatar
These are definetly not heads off of a Big Block Chevy.The valves on a BBC are splayed,or I guess you could say they are angled away from each other,or "Porcupined"as they say.
Old 06-13-2006, 06:34 PM
Jmark's Avatar
Those ARE Ford heads, NO doubt 'bout it!
Old 06-13-2006, 06:40 PM
Gone fishin'
Wiki Edits: 2
I forgot the BBC had the kinda staggered valves
I guess I was told wrong then. Im just glad I didn't pay anything for them.
Live and learn
Thanks guys
Brad
Old 06-13-2006, 07:59 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
Maybe he was thinking of a 460.simple things usually slip peoples minds at times.
Old 06-13-2006, 08:49 PM
WV hillbilly
Last journal entry: PTL 220CC
Look like small block ford heads to me, actualy looks like a set of early small block ford castings, whats is the casting #?
2wld4u
Old 06-13-2006, 09:09 PM
Gone fishin'
Wiki Edits: 2
3030 302 FW
those were the only numbers I found anywhere.
Brad
Old 06-13-2006, 10:30 PM
onebadmerc's Avatar
I need a bucket of arc sparks
From what I can see of the combustion chambers, these look like 68-70 Ford 302 heads with 63 combustion chambers and non adjustable rail rocker arms.
BBC 454 combo NOlowrider Engine 3 03-28-2006 05:26 PM
BBC heads and exhaust manifolds (marine) beemer nut Engine 0 07-24-2005 04:17 PM
454 Heads -- did I blow this deal? 66GMC Engine 16 07-14-2005 09:25 PM
bbc heads slim Engine 0 05-25-2003 08:37 PM
Use of these BBC Heads WRevels Engine 2 02-17-2003 08:05 AM
