454 big block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2009, 06:37 PM
454 big block?
ok so i am replacing a 400 small block with a 454 big block and im wanting to know what kind of mods or if any, i would have to do. would it bolt right to my th350? thanks
Old 01-15-2009, 08:28 PM
DoubleVision's Avatar
You`ll have to change to big block mounts, even so the small block mounts will work, it`ll likely sit too high. Yes, it`ll bolt up to a TH350.
Old 01-15-2009, 09:27 PM
re
its going in a 76 chevy 3/4 ton. so it would sit to high?
Old 01-16-2009, 09:39 AM
SSedan64's Avatar
Hood clearance shouldn't be a problem in the truck, depending on intake height/type.
Old 01-16-2009, 12:53 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Motormounts are different than the small block in these trucks.
The BB mounts even use different holes in the frame
The clamshell can be used tho.
Exhaust will need to be changed
Wiring to the Alternator may be too short
Wheezy small blockradiator won't get it.
Try to find the upper support from any "heavyduty cooling truck"
The radiators are about 3" taller and a radiator from a BB Chev/GMC or a diesel.
Fan shroud will also need to be changed
Old 01-16-2009, 11:20 PM
re
ok so just the motor mounts ,the radiator, the fan shrowd and alt wiring needs to be changed? thanks
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
wanting to twin turbo a 454 big block cherry_camaro Engine 25 07-25-2009 04:26 PM
427 Big block blew up, need a few suggestions. esears Engine 17 03-12-2007 09:18 AM
69 Camaro Big Block Underhood Photos?? EricTopless68 Camaro Engine 4 03-10-2004 07:03 PM
picture's of big block s10 my454s10 Engine 6 09-17-2003 07:57 AM
